vcBehavior
Behavior is the basic implementation of all behavior objects.
Module: vcBehaviors
Children: vcActionContainer, vcCapacityController, vcComponentPathSensor, vcFlow, vcJogInfo, vcNote, ... (see more)
vcActionContainer
vcFlow
vcJogInfo
vcNote
vcRaycastSensor
vcRrsRobotController
vcScript
vcSignal
vcSignalMap
vcSimInterface
vcStatistics
vcVolumeSensor
vcProcessController
vcProcessExecutor
vcTransportController
vcTransportNode
vcBaseContainer
vcPythonKinematics
vcPythonProcessHandler
vcRobotExecutor
vcServoController
vcToolContainer
vcKinematics
vcMotionController
vcProgramExecutor
Referenced by: vcConnector.Behavior, vcCore.getBehavior(), vcGetPropertyStatement.SelectedBehavior, vcMoveJointStatement.Controller, ... (see more)
vcNode.Behaviors
vcNode.createBehavior()
vcNode.findBehavior()
vcNode.getBehaviors()
vcProgramExecutor.Controller
vcProgramExecutor.DigitalInputSignals
vcProgramExecutor.DigitalOutputSignals
vcPropertyConditionStatement.SelectedBehavior
vcRobotController.Kinematics
vcRobotSelectionService.ActiveController
vcRobotSelectionService.ActiveExecutor
vcRoutine.Executor
vcSendSignalStatement.SelectedSignal
vcSimBaseExportField.BaseList
vcSimProcessorField.Sensor
vcSimToolExportField.ToolList
vcTransportLink.Implementer
vcWaitSignalStatement.Signal
vcWorld.Behaviors
ComponentvcComponentRGets the component this behavior belongs to.
EnabledBooleanRWGets or sets value indicating if this behavior is enabled or not.
NameStringRWGets or sets the name of the behavior which is unique for every behavior in a component.
NodevcNodeRGets the node this behavior belongs to.
PropertiesvcPropertyContainerRGets the properties of this behavior.
TypevcBehaviorTypeRGets the type of this behavior.
VisibleBooleanRWGet or Sets value indicating whether this behavior and its properties are visible in the user interface.
WorldvcWorldRGets the 3D world (simulation root node).
deleteNoneNoneDeletes the behavior.
ValueError: When trying to delete behavior from the world root node.
evaluateNoneNoneEvaluates the behavior.
